I’m trying to run klipper on an octopus 1.1v and still works fine, but abount stepper motors, them are not moving.
Here there is my printer.cfg:
printer.cfg (5.3 KB)
And yeah, I checked all connections.
Any idea?
Any idea?
Hello @Nathanub !
Problems and issues always please into the subforum General Discussion (See the note when you opened this thread, I moved for you).
Please attach the klippy.log to your next post.
How did you tried to move them? Do you get an error message?
I tried to move axies throught octoprint, and when I move axies it says: " OctoKlipper: Error: Must home axis first: 0.000 10.000 0.000 [0.000]"
And when I try to start autohome octoprint says: “No trigger on x after full movement”, becouse stepper keeps stop.
Anyway this is my klippy.log:
klippy.log (450.8 KB)
Check your config against https://github.com/bigtreetech/BIGTREETECH-OCTOPUS-V1.0/tree/master/Firmware/Klipper
I have modified “enable pin” adding the “!”, but the stepper still not moving.
And I’m using the default drivers of octopus 1.1v.
I can’t know the problem.
There are no “default drivers”. Most likely you are using TMCs, so find out which ones and add the respective settings.
In general:
Oh, that’s why it didn’t work!
Thank you so much!
