 Printer Model: Monoprice Delta Pro
 MCU / Printerboard: Orange Pi LTS / Lerdge X
I am still new to Klipper.
I wrote a set of macros and a gcode file to probe the bed to create a 15 x 15 mesh using an alternative method that works better for delta printers.  I output the mesh points to the console so that they can be copied and pasted into the printer.cfg.  I use filters to suppress the undesired outputs from the probing.  It looks right on the console.  However, the console filters (Fluidd), only filters the display.  The console buffer is still filled with all the extraneous probe result reports.  This causes me two problems.  The biggest one is that all the extra data filles up the amount of space in the console and it throws away half of the data.  The second one is that a Copy and Paste of the console, copies ALL the data, not just the visible data.
My current workaround is a painful and time-consuming amount of screenshots in realtime and image to text conversion and text editing to put it all back together again. I need a better solution.
I am not sure where to look to find a solution.  Is it in Klipper to make it suppress the probing output?  Is it in the Fluidd console?  Or perhaps switching to Mainsail can get double the console field size?
Or is there some other way to send the output to a file to bypass this problem?
I am open to all suggestions, but I am not a Python programmer (or I would have rewritten the built-in probe command to include my algorithms).
