Hybrid corexy(markforged) issue
I have 3D printer with markforged(Hybrid corexy) kinematics, according to image. The extruder moves normally along X axis. If printer moves Y axis, the gauntry moves normally, but the extruder moves along Y and X axis simultaneously. If i reverse X stepper, the extruder moves normally along Y axis, but in the opposite way only along X axis(reversing Y stepper gives similar result).
How can i reverse X axis? Do i need to rotate the gauntry?
Have same issue. Did You find any solution for it?
https://www.klipper3d.org/Config_Reference.html?#hybrid-corexy-kinematics
I have flipped the gantry. Config_reference has no solution.
I think swap B1 and B2 and might help. In your case it will be stepper_x and the dual_carriage
Did you find a solution to this problem?
I thing it is possible, that something with the rotation_distance is not correct. If the Y and X1 or X2 is not spot on, that can cause this problem.
Have you checked it?
Hello @b4lala !
You noticed this?
grafik
Thanks for the useful comment! I did not saw that that coming. xd
Yes I noticed the date.
But.
I’m curious about that problem and the solution now and I don’t see that here yet.
Do you noticed this?
Do you know the answer for the original question?
As there is no post marked as Solution, there is obviously no solution.
You may have a look on the link in post #3
you can do the following in printer.cfg
-[stepper_x]
-dir_pin: !PA1
“!” inverts the turning direction.
Or… you can flip some wires in your stepper :zany_face:
