Printer Model: tronxy x5sa
MCU / Printerboard: manta m8p
…I keep getting the error Unable to parse option ‘max_z_accel’ in section ‘printer’
klippy (2).log (467.9 KB)
Hello @EvanGel !
In this case please upload your printer.cfg. Please zip it.
thank you
generic-bigtreetech-manta-m8p-V1_0.zip (1.8 KB)
This block here gives the error.
You have commented out the the board_pins module loading, but not all the lines defined for it.
Remove the whole section or comment all lines in it and restart.
#[board_pins]
#aliases:
# EXP1 header
EXP1_1=PE9, EXP1_2=PE10,
EXP1_3=PE11, EXP1_4=PE12,
EXP1_5=PE13, EXP1_6=PE14, # Slot in the socket on this side
EXP1_7=PE15, EXP1_8=PB10,
EXP1_9=<GND>, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PB14, EXP2_2=PB13,
EXP2_3=PF7, EXP2_4=PB12,
EXP2_5=PE7, EXP2_6=PB11, # Slot in the socket on this side
EXP2_7=PE8, EXP2_8=<RST>,
EXP2_9=<GND>, EXP2_10=PC5
In general this seems like an incomplete config.
printer.cfg
Not clear what you are doing currently.
I am completely new to this.
deleted it and still getting the same error.
config-202341-14919.zip (1.7 KB)
already addressed above
You cannot just leave arbitrary snippets in the config and then wonder why it does not work.
Strip down the config to what you effectively need / hardware that you have and remove the rest.
