Imprimante sovol sur klipper
Printer Model: sovol S06 plus
MCU / Printerboard:TMC2229
Host / SBC je c’est pas c’est quoi
klippy (2).zip (87.9 KB)
Good morning
I installed the Sovol box but it works at the beginning and a few days later it doesn’t work anymore. I didn’t look for anything as a solution so I bought a raspberry. I redid the installation but now it’s getting a message. mcu ‘mcu’: Unable to connect
Error configuring printer
I have however checked the serial change the cables but nothing changes I hope you will find me a solution
THANKS
Hello @yan37 !
This is an English speaking forum.
Please write in English - you may use an online translator.
Good morning
I modified thank you
What is the output of the ls /dev/serial/by-id/* command?
serial:/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
now I have this error message I can no longer modify the files if I have to do it I will give you a photo of mainsail
This cannot be the output of the above command. The screenshots from mainsail are of no use.
If you anyway moved to a RPi, it might make sense to start clean and go step by step: Installing Klipper with KIAUH
I redo the entire installation with the link you provided me?
Capture
yet it tells me a result
I started the installation I show you a picture I think it’s good
Good morning
a big thank you it works apart from it’s errors I but in photo you can tell me how to add a printer on mainsail once again a big thank you to Sinéos
I don’t know anything, I’m waiting for your help
Crownsnest is needed for operating a webcam. So if you use one, you should install it with KIAUH.
The required settings and macros for controlling time-lapse etc, can be found here:
If you do not use it, then remove the crownsnest entries from the moonraker.conf file
Good evening
thank you why I don’t have more macros I added on the printer [include mainsail.cfg] I tell you but the printer.cfg file is a photo
printer.cfg (2.8 KB)
thank you again for your valuable help
I’m not sure what you are expecting. The Mainsail macros do not offer more. They are mainly targeted at PAUSE and RESUME handling.
In general, please always include a klippy.log when posting any issue or question. Also on follow ups, so that we can check where we currently stand.
