Is outside of configured range
Printer Model: Troodon 2.0
MCU / Printerboard: based off the octopus
klippy (2).log (979.0 KB)
I cannot for the life of me figure out this issue. Still rather new to klipper and I’m having a hard time tracking this down. The error I get is this Offset -1.288 is outside the configured range of min=-1.000 and max=1.000 and I don’t understand what its asking of me to fix or to change. I’m using pcb klicky just incase id like to add that if its helpful.
Quite simple: Do not use unofficial modules from “somewhere” and you will not have this issue.
As in the pcb klicky probe?
As in:
Git version: 'v0.11.0-304-gf7567a0d-dirty'
Untracked files: klippy/extras/z_calibration.py
I appreciate the help but being so new to this i’m very lost and starting to think klipper is to much for me at this point.
You have installed an unofficial additional module: GitHub - protoloft/klipper_z_calibration: Klipper plugin for self-calibrating z-offset
This module is now causing the issue and unless you know how this module works and you really need it, I recommend removing it.
