KAMP LINE PRUGE Unknown command:"LINE_PURGE"
Printer Model: Voron 2.4
MCU / Printerboard: BTT Manta m8p V2 + CB1
klippy.zip (2.2 MB)
Hello everyone,
my Voron is now running (more or less). I’m just getting the macros up and running.
At the moment I can’t get any further with the adaptive line purge. Adaptive bed msah and exclude objects work. I also added “max_extrude_cross_section: 5” to the extruder.
But I still get the following error: Unknown command:“LINE_PURGE”.
Thanks in advance for the help
Arni
Too bad:
You copied so may macros and missed the LINE_PURGE macro?
Is the LINE PURGE in the KAMP folder not sufficient?
Do I need a “normal” LINE PURGE in addition?
I don’t use KAMP, so I don’t know what’s in the folder, but no [gcode_macro LINE_PURGE] appears in the log
Thanks for the info, I’ll try it
