Kingroon KLP1 Error mcu 'MKS_THR': Unable to connect
Printer Model: Kingroon KLP1
MCU / Printerboard: Kingroon Cheetah V1.1
klippy.zip (1.4 MB)
I got my KLP1 two days ago and just did some calibration and test printing up until now. But today i turned it on, after a while the fans started to speed up and i got the klippy error:
mcu ‘MKS_THR’: Unable to connect
Error configuring printer
Now i can’t really do anythig. I don’t really know too much about Klipper so i have no idea how to fix it.
Thanks in advance.
You can directly attach the klippy.log here into the post.
If it is too big just zip it.
@LifeOfBrian : Agree. Google drive always mixes up my tabs.
@kwedl :
You may check:
[mcu MKS_THR]
serial = /dev/serial/by-id/usb-Klipper_rp2040_B5D94D150CDA5658-if00
Are you running one Debian Bullseye?
I’m not too sure. I just bought the printer, connected it via Ethernet and run it with Fluidd.
But now everything is greyed out and unavailable. Here is an image of Fluidd and the mainboard while the printer is running if that helps.
Hi there, i have had same problem with Kp3s Pro V2, check main cable on hotend, the black one with 4 cables, try to disconnect and connect correctly again, it fixed same problem on my printer.
klp1 the cable hoted is unsoldered due to the vibration and speed, that is why it gives that error
