Printer Model: Custom
MCU / Printerboard:Manta M8P, EBB42 Gen 2 (toolboards)
Host / SBC CM4
klippy2026-07-25.zip (5.8 MB)
** I have deleted some lines of the log since it exceced the maximum size of the upload
I’m getting random Timer too close shutdowns.
I previously replaced all my older BTT EBB42 boards with the newer EBB42 Gen2 because I suspected the older boards were causing stability issues related to scheduled OIDs/digital outputs.
However, I’m still occasionally seeing Timer too close.
From what I’ve seen so far, I believe the issue is related to the extruder heater PWM output, but I’m not completely sure.
Could this still be related to OID scheduling or delayed digital output updates? Is there anything specific I should check or any known cause for this type of failure?
I’d really appreciate any help.
I don’t know if this could be related to some delayed macros I use for various checks, or perhaps to the configuration of my outputs or heaters.
Please take a look at my configuration and log. I’m completely lost with this issue.
