Printer Model: tronxy veho 600
MCU / Printerboard: stock
has anyone used and successfully setup an osoyoo 5inch touchscreen with a rpi 4b for klipperscreen? looking for help. thanks
tronxy veho 600
standard control board
osoyoo 5inch touchscreen to use for klipperscreen.
i have connected the screen to the rpi and the screen works, just not the touch part of it. so i swapped out sd cards and put a non klipper pi os in and the touch part works fine.
so i then got in contact with the manufacturer of the screen, he thinks there is a conflict with the i2c address as the touch part of the screen uses the i2c “channel”.
unfortunately i cant change it for the screen so i must somehow change it for the printer. does anyone know how to do this?
thanks in advance
note: i thought setting up klipperscreen might remedy the problem, but no. now im worse off because i need to reconnect to the network on my rpi as per the final instruction from the install
“”“if you were not using networkmanager you will need to reconnect to the network using klipperscreen or nmyui or nmcli”“”
but since the touchscreen doesnt work i cant do so and now i cant ssh into it because its not connected. it might aswell be a brick
if anyone has experienced this problem before and found a fix please get in touch. thanks
Pleas do not open multiple threads on the same topic.
I’m not sure that I understand what you are reporting.
Just some general notes:
I neither own an Osoyoo nor an Raspberry Pi Touch Display 2!
Marc’s post may help
The link provided above leads to “FEATURE”
Point 5 states: 5 finger capacitive touch (but Raspbian only support 1 finger)
IMPORTANT: Some people stated, USE THE ORIGINAL CABLE, which comes with the display. Other Flat Flexible Cable (FFC) might not work for every feature!
https://www.raspberrypi.com/documentation/accessories/touch-display-2.html#install
Raspberry Pi Touch Display 2 is also a capacitive five-finger touch.
I would follow both (maybe the RPi documentation a little more) installation instructions and use the Squeekboard on-screen keyboard instead of the matchbox-keyboard, but you may use the “try and error” method here.
If your display is completly working with your RPi 4b (touch working too), then follow KlipperScreen/docs/Hardware.md at master · KlipperScreen/KlipperScreen · GitHub.
Good luck, hcet14
