I use an Octopus Pro 429 board, as you know the problem with this board is that you have to flash the Klipper image manually, with an SD…
But where is the latest version of Klipper for this board? (Octopus pro 429).
On the web (Releases - Klipper documentation) it says that the latest version is 0.10.0, the date it says is 2021/09/29. Sounds like I’ve seen that there are more updated versions. But I don’t know where I can find it.
Next step… I have updated Octopus with latest version of Klipper.
But i am not sure, think that it’s OK, that latest Klipper version it’s installed…
How can I check the version of klipper installed in Octopus? (maybe a console command)
I use a fork of Mainsail, adapted by Ratrig for the printer.cfg… There is a resumen of the latest version… But not ensures that its installed in Octopus…
