Printer Model: TwoTrees Sapphire plus
MCU / Printerboard: Orangepi 3b / BTT SKR V1.4
hi all, can a 24V led strip, naturally the power supply is a 24V, can be connected to HE1 and controlled in Fluidd?
@killrob ,
Technically, yes. But you could also simplify things and connect it directly to your printer’s PSU if it is 24V and has enough spare current.
Yes you can. Just define a LED pin as following if it’s a one color white strip:
[led chamber] # Led will be named "chamber" in UI
white_pin: P2.4 #HE1 on SKR 1.4
initial_white: 1.0 #starting brightness, between 0 and 1
TY both for suggestions ![]()
