Mainsail and Klipper logs show time as UTC
klippy.log (1.3 MB)
Printer Model: Ender 3
MCU / Printerboard: SKR Mini E3 V3
Host / SBC: RPI 3b
…Mainsail time and Klipper logs show UTC time not local time. System (Windows 11) and Chrome browser display local time. How to fix this?
Just set Windows time zone to UTC. :grinning_face_with_smiling_eyes:
or
set the time zone of the
to your local time zone
I never paid it much attention but now that I look:
SBC is set to UTC
Klipperscreen also displays UTC
Fluidd and Mainsail both (Win11 + DuckDuckGo Browser) display local time (UTC-8)
If you wish to set your Host to local time this may help:
https://www.cyberciti.biz/faq/find-checking-timezone-in-linux-using-command-line/
I did set it via SSH to my time zone which is the same as my system. Cuurently my timezone i Americas/Toronto ET. Sytem and Chrome show time as 3:30 PM while Mainsail displays time as 8:30 PM. I have gone through the sudo raspi-config several times as well as checked and rechecked my system time settings. RPI ‘timedatectl’ result: Local time: Mon 2026-02-09 15:19:14 EST
Universal time: Mon 2026-02-09 20:19:14 UTC
RTC time: n/a
Time zone: America/Toronto (EST, -0500)
System clock synchronized: yes
NTP service: n/a
RTC in local TZ: no
Update: I have installed NTP service and rebooted the RPI which resulted in No Change in time discrepancy.
Question: Is it necessary to have an RTC installed on the RPI?
I think yes. The file system, for one, timestamps everything.
I think the way linux is setup, all systems everywhere actually run UTC. The time zone offset comes into play for “Human readable” outputs. Point is Klipper copies the system time into the log. Adding a subtraction operation to every time stamp seems silly.
I think it makes sense when the Pi has no connection to the Internet.
Usually at every startup, the OS gets the actual time from the net.
