Printer Model: Ender 3 (original)
MCU / Printerboard: SKR_Mini_E3_V3.0
Host / SBC: RPI 3
klippy.log (177.2 KB)
I do have the ‘MECHANICAL_GANTRY_CALIBRATION.cfg’ and it is referenced in ‘osskc.cfg’.
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
I’ve had Klipper running on RPI3b connected to Sovol SV06 for some time. I have added a 2nd printer, an Ender 3, to rhe RPI. I used KIAUH to remove Klipper and Moonraker. Then I installed both with two instances and also created a .bin file for the Ender 3.
I can connect to Mainsail Web interface and can start the first (SV06) printer with no errors. When I try to start the Ender 3 I get ERROR: ‘Section ‘menu __main __setup __calib __mech_gantry_calibrate’ is not a valid config section’.
I have been tryin to resolve this for a day now and I think it’s time to get help.
HELP!!
