Printer Model: Home Built
MCU / Printerboard: MKS Gen LV2.0
octoprint.log (1.4 MB)
plugin_klipper_debug.log (66.1 KB)
Describe your issue: I keep getting MCU ‘mcu’ shutdown: Rescheduled timer in the past. errors. I have tried several different solutions related to others having this problem, but it does not solve my problem here.
I also attached a Gcode of a file that causes the problem within the first fews seconds of print starting. … oops. I cannot select a gcode file to upload.
