Mcu shutdown when homing
Just built my voron 2.4 and every time I try to home any of my axis the z axis goes up a bit then the error mcu shutdown comes up please help
klippy 4.log (1.6 MB)
Transition to shutdown state: MCU 'mcu' shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Basically exactly what the error message says. Ranges from playing Counter Strike on the RPi to a failed / failing SD card.
