Printer Model: Creality CR10S
MCU / Printerboard:
Host / SBC: Raspberry Pi w/ Klipper Screen
Hello! I have been having some trouble calibrating my new Extruder. The manufacturer says that the E-Steps need to be set to 400, but I really don’t know how to set this. I tried to use a measure and trim method to calibrate, but it always under extrudes by 20mm+. Does anyone have any experience with this extruder? Thanks!
klippy.log (105.1 KB)
They speak of Marlin and hence using esteps = 400. Although this needs to be calibrated too as it is rarely such an even number.
Klipper uses rotational_distance instead of esteps though you need to define full_steps_per_rotation or omit it for a 1.8° stepper driver.
You want to read here:
https://www.klipper3d.org/Rotation_Distance.html
A short research showed that you should try to calibrate your feeder with a base rotational_distance: 8.
Thank you! I will try that and let you know how it goes.
