Printer Model: Ender 5 Max
MCU / Printerboard: co-print KCM
Host / SBC moonraker
I have an Ender 5 Max, and recently tried to install a co-print KCM (4 extruders).
Linux 4.4.94, FW 1.2.0.21
I have followed the manufactures installation instructions but have got stuck at where Moonraker tries to connect to klipper. It asks about the klipper service state and the klippy_uds_address that would be configured in moonraker.
I can not find a klipper.sock file on my system anywhere.
The “service” for klipper is /etc/init.d/S55klipper_service, moonraker is in the same directory S56moonraker_service.
so really stuck, please help.
idribble.
klippy.log (1.1 KB)
Hello @idribble !
Are you sure that is the klippy.log you took form the system?
The are a lot for formatting parameters that do not belong to the log.
How did you setup your Klipper system?
Hey there,
I accidentally included part of another file. Sorry about that.
I remove the log file and then restarted the klipper service, here is the output
Starting Klippy…
Args: [‘/usr/data/klipper/klippy/klippy.py’, ‘/usr/data/printer_data/config/printer.cfg’, ‘-l’, ‘/usr/data/printer_data/logs/klippy.log’, ‘-a’, ‘/tmp/klippy_uds’]
Git version: ‘v0.13.0-253-g96c3ca160’
Branch: master
Remote: origin
Tracked URL: GitHub - Klipper3d/klipper: Klipper is a 3d-printer firmware
CPU: 2 core ?
Python: ‘3.8.2 (default, Oct 24 2024, 13:27:57) \n[GCC 7.2.0]’
Building C code module c_helper.so
Unable to build C code module (error=32512)
I used a coprint youtube video to install the platform, but the instructions are the same at this site too:
this is the output in the moonraker.log file:
2025-09-06 23:59:09,158 [common.py:build_error()] - JSON-RPC Request Error - Requested Method: printer.info, Code: -32601, Message: Method not found
2025-09-06 23:59:13,256 [common.py:build_error()] - JSON-RPC Request Error - Requested Method: printer.info, Code: -32601, Message: Method not found
thanks in advance
idribble
For installing Klipper on a SBC, KIAUH is strongly recommended.
In all, this seems very Creality specific. 3D Printers with Preinstalled and Modified Klipper Versions
You may ask the author of that upgrade.
