Need Help in disabling Stepper motor Y axis
Printer Model: Custom model
MCU / Printerboard:BTT SKR V1.4
klippy (1).log (115.3 KB)
want to disable Y axis in Klipper, though i removed Stepper Motor Y Section it is still asking for Stepper-Y.
it is for a custom project that just uses XZ axis. hence wanted to completely remove Y axis config, including Z movement restriction as Y is not homed
Not 100% sure but pretty confident that this is not going to work.
The expected axes are tied to the
[printer]
kinematics: ...
setting and probably Klipper will refuse to start if the respective axes that are needed for the given kinematics are not configured.
You can try if the special none kinematic will take you anywhere.
Very unsure https://github.com/Klipper3d/klipper/blob/master/test/klippy/manual_stepper.cfg
Good luck, hcet14
