New to this, hotend rams into side
Printer Model:
Ender 3
MCU / Printerboard:
SKR Mini v1.2
https://termbin.com/2f2c
I tried to follow the manual on the site as good as I can. I thought I was getting this done right. But then I ran into this.
When I query the endstops, they are all open. When I press one, it says triggered. That’s great. But now when I home, It rams the hotend right into the left extrustion and wont stop moving into it, making a ton of noise. I have no idea what to do, I really hope someone can help me. I’m sure something is wrong, I just don’t know what.
Are you sure that your carriage, bed, whatever is physically hitting the endstop when homing?
Is that problem existent on all axes?
If one axis moves into the wrong direction, i.e. away from the endstop, then you need to invert or un-invert the respective dir_pin (add or remove the ! before the pin)
E.g. modify
dir_pin = !PB12
to
dir_pin = PB12
Ohhhh no you got to be kidding me…
I used a tie wrap to redo the cabling, but put the cables on the (from the front) left side of the hotend.
It’s not touching the endstop… I spend a week trying to figure out what’s wrong. This was so obvious, yet I totally failed to check this.
Thank you for pointing it out. I can’t believe I made this mistake.
Thanks for the tip. Royce solved this for me. Turns out that the problem was between the keyboard and the chair. Not a Klipper issue but an OSI layer 8 issue.
