Not able to print after setting up printer
Printer Model: DIY Anet A8 + Ender Sprite extruder/hotend
MCU / Printerboard: BTT M5P + CB1 V2.2
klippy (9).log (5.1 MB)
moonraker (1).log (182.5 KB)
printer (4).cfg (4.8 KB)
Running on 12V 40A power supply
…Finally I managed to install klipper to BTT Manta M5P+CB1
I have two issues though.
  1. Getting this error message when it starts to print: “Move out of range: 160.000 10.000 0.200 [15.000]”. What does it mean?? And what to do to fix it?
  2. When I activate pin PA4 to my FAN0 (12V) the MOSFET blows. Fan is a 12 V with right polarity (jumper is on 12V). Why is this happening? What can i do?
Everything else is working on the printer.
And yes I will change to a 24V 30A power supply :slight_smile: )
Hope someone canbring some light over these issues!
You may read here: Understanding X and Y Axes Limits and Homing
What do you mean by that?
plus
You will need a new fan, also a new heater cartridge.
Hi Eddy,
Thanks for your quick reply :+1:
Both fans, the hot end fan and heater fan are 12 volt. This is set by the12V jumper on the board.
Regarding the heater cartridge. This one is a 24V cartridge. This way it takes ages to get hot :blush:.
I think I found the cause to my warning issue!
I forgot to unmark the tmc2209 lines in the printer.cfg file.
Will try it out later today.
/Kent
