Checked the Klipper Documents none is a valid setting for kinematics.
It is, however, none defines no axes. So all [stepper_] sections are invalid:
This config file:
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_240050000F51383438343939-if00
[printer]
kinematics: none
max_velocity: 1000
max_accel: 1000
[stepper_x]
step_pin: PF13
Produces this error:
Section 'stepper_x' is not a valid config section
And in the klipper log:
Config error
File "/home/pi/klipper/klippy/klippy.py", line 130, in _connect
self._read_config()
File "/home/pi/klipper/klippy/klippy.py", line 127, in _read_config
pconfig.check_unused_options(config)
File "/home/pi/klipper/klippy/configfile.py", line 497, in check_unused_options
self.validate.check_unused(config.fileconfig)
File "/home/pi/klipper/klippy/configfile.py", line 441, in check_unused
raise error("Section '%s' is not a valid config section"
configparser.Error: Section 'stepper_x' is not a valid config section
OPās config isnāt valid. I donāt know what config exactly generated the error they posted, but I kinda doubt its the one posted here.
(that or something they did to klippy/configfile.py caused a different error to be produced?)
Well, thatās the question
I think Iāve answered your question. If you would just like your setup to start working, you need to pick kinematics that is not none.
You may need to develop your own kinematics for a robot arm. You should read this Adding New Kinematics
As your log indicates:
Git version: 'v0.12.0-458-gd886c1761-dirty'
Modified files: klippy/configfile.py
You made some kind of code change to the way config files are read. We cant guess whats going on with that because you havenāt shown us a git diff. You should revert this file, nothing you want to do requires changing it.
