Printer Model: Infimech TX
MCU / Printerboard:
I have a Infimech TX that I got used from a friend because I am new to this, and he got to a point in trouble shooting where he was just done.
The problem is if you push X- it goes left. press X+ it moves towards you. And if that is not weird enough if you press Y- if moves towards you and Y+ it moves to the left.
If you home it the head moves to the left front corner and makes a bunch of racket moving left and right a tiny bit as well as in and out a tiny bit.
I have updated firm ware made sure all the plugs were seated correctly. I did a factory reset (it didn’t delete all the local config files) and that make a real mess because it was trying to home out.
