Problem with printer.cfg
Printer Model: Ender 3
MCU / Printerboard: SKR Mini E3 V1.2
Host / SBC Dell/LAPtop Debian 12
…very new to klipper. trying to make Ender 3 with Skr mini E3 V1.2 bl-touch to work on old laptop running debian12.
have installed with KIAUH
klipper
Monraker
Mainsail
Fluidd
Octoprint
Problem:
  1. Can connect to printer with Mainsail and Fluidd
    Not with Octoprint.
  2. When connect get error: Option ‘mesh_min’ in section ‘bed_mesh’ must be specified
As you can see in printer.cfg I have put:
[bed_mesh]
speed: 80
horizontal_move_z: 5
min_point: 90, 20
max_point: 235, 235
probe_count: 3,3
fade_start: 1.0
mesh_pps: 2,2
tryed to comment out min/man with# but receive the same
Octoprint have klipper plugin and I have done ‘ls ./dev/serial/by-id/*’
and put that in octoprint but no connection.
sorry for bad english (not my navtive langue) and hope maybee you can point me in the right direction to solve these issues.
/Flegge
Log.zip (10.0 KB)
found it out … shuold be ‘mesh_min and mesh_max’ not min_point and max_point.
but still no connect with octoprint
What virtual port do you use?
I follow instruction for knowing ‘printer port’:
got
/dev/serial/by-id/usb-Klipper_stm32f103xe_31FFD8054242363126552457-if00
and it works for Fluidd and Mainsail but not Octoprint.
Have not ‘seen’ any instruction for a ‘virtual port’, where can I find info for this ?
That is for connecting Klipper to the printer.
You need to connect OctoPrint to Klipper now.
Either with
/tmp/printer
When you install the OctoKlipper image
When you use KIAUH, then you have to use:
/home/pi/printer_data/comms/klippy.serial
But you first have to set it up in OctoPrint:
Thank you very much. Now its working
