Problem with Z direction and homing
Printer Model: Enderwire
MCU / Printerboard: SKR e3 Mini v2
Hi!
I’m configuring my new Enderwire and I have a problem: it’s trying to home z on the top but I have an endstop on the bottom.
Then I mounted an endstop on the top and obviously it’s homing correctly st I figured out that the direction is wrong, even if was good using FORCE_MOVE_STEPPER, after homing the direction looks inverted.
Now, after inverted the direction pin I have a different behavior, the homing starts with Z (not with X) and it crashes into the bed, no matter if I phisically press the endstop (that worked good on my test putting it on the top.
This is my config with the direction good (homing starts with Z and crashes into the bed).
Thanks!
step_pin: PB0
dir_pin: !PC5
enable_pin: !PB1
rotation_distance: 40
full_steps_per_rotation: 200
microsteps: 32
position_endstop: 0
endstop_pin: ^PC2
position_min: -1
position_max: 235
homing_speed: 40
[tmc2209 stepper_z]
uart_pin: PC11
tx_pin: PC10
uart_address: 1
run_current: 0.580
interpolate: True
stealthchop_threshold: 0
UPDATE: looks like changing the Z dir_pin switches X with Z, is this normal on corexz? Thanks!
UPDATE 2: fixed, Z and X connectors were reversed.
klippy.log (1.7 MB)
Hello @SGr33n !
What happend to this?
grafik
Please attach the klippy.log file to your next post.
Sorry, klippy.log added.
Thanks :slight_smile:
I said this for a reason: It is to keep the workflow simple.
Sure, thanks for your work :slight_smile:
