Sorry, but my previous post was translated by the translator and that’s why that post was closed. ![]()
| Component | Ender 3 V2 Neo | Ender 3 S1 Pro |
| Board | Creality V4.2.2 (GD32F303RET6) | Creality V2.4.S1 (STM32F401CCU6) |
| Host Controller | Raspberry Pi 4B (64-bit OS) | Raspberry Pi 4B (64-bit OS) |
| Klipper | v0.12.0 | v0.12.0 |
| Moonraker | v0.9.3 | v0.9.3 |
| Fluidd | v1.25.0 | v1.25.0 |
Core Issue
The problem began when I tried to flash Klipper on both printers. Despite following all official steps and multiple guides, nothing worked.
Incorrect Hardware Detection
When connecting the printers via USB and running lsusb, the system identifies them as:
- Bus 001 Device 010: ID 1a86:7523 QinHeng Electronics CH340 serial converter
This is strange because (I asked an AI since I couldn’t find this specific problem documented anywhere) they should appear as “GD32” (Ender 3 V2 Neo) or “STM32” (Ender 3 S1 Pro).
Klipper Cannot Communicate
When starting Klipper, constant errors appear in the logs:
- “JSON-RPC Request Error: printer.info - Method not found”
This indicates Klipper can’t talk to the boards, as if they weren’t there.
Failed Flashing (I think - no way to confirm)
I’ve tried:
- Different filenames: firmware.bin, firmware-CREALITY.bin, firmware69.bin, firmwareql.bin, etc. (Files never exceed 40KB, always 36-38KB)
- SD formats: FAT32 with 4096-byte clusters
- Reinstalls: Klipper reinstalled 7+ times (via KIAUH and manually) (with respective reflashes)
But the bootloader never responds:
- The screen either freezes on the logo or shows nothing (which should be normal with Klipper), but the firmware doesn’t load.
- No flashing records appear in
dmesg(nothing like dfu or stm32).
What I’ve Investigated and Tried
I found no references, but when I asked an AI, it suggested the “CH340” chip (used for USB-serial communication on these boards) might be blocking bootloader access. That is:
The CH340 hogs the USB connection, preventing the computer from seeing the main MCU (GD32/STM32).
- This is why
lsusbonly shows CH340 and not the real microcontroller. And I don’t know how to fix this.
Bootloader Locked or Inaccessible
In theory, these boards’ bootloaders should:
- Read the .bin file from the SD card on startup
- Load the new firmware
But in my case:
- Filename doesn’t matter** (I’ve tried all suggested ones)
- Folder doesn’t matter** (even STM32F4_UPDATE)
- The bootloader simply doesn’t respond**
The AI told me:
- GD32F303**: Klipper has experimental support, but Creality’s bootloader might be modified.
- STM32F401**: The CH340 might be preventing DFU mode entry (required for flashing).
