Printer Model: Any QGL
MCU / Printerboard: NA
Host / SBC NA
klippy.log NA
For a bed that is not centered with respect to the four Z axes, which 4 points should be probed in the attached image, the blue dots or the orange ones?
I have a general understanding that the bed plane should be parallel to the gantry, however, does the location of probing points affect how much strain will be placed on frames when QGL is running or it is done, or how fast it will be able to achieve the parallel planes?
Also, it seems the points are where the nozzle is sent, and the probe will have offset in X-Y axes. Do I need to account for that in the coordinates that I put in the quad_gantry_level section?
My first guess was that the probe points should not matter that much if they are separated enough and close to edges, but I am not sure.
