With klipper’s resonance compensation, how would it work you were to add “resonance curves”?
Where we for instance have variables in printer.cfg by adding the measurements of 1500 accel, set it’s hz, 2000 accel, 2500 and so on, same with print speeds, or velocity, and have say a variable users adjust when measuring the print where it’ll adjust the acceleration automatically based on the gcode’s current speeds? Or would this not make a single difference vs setting one acceleration speed?
