Been away from 3d printing for 6 years and trying to get up to speed with new ‘Everything’. I am rebuilding with the following:
Mendel90 dibond, original motors and bed
Manta 8P with CBI, TMC2209 drivers
E3D V6 hotend
24V supply [new].
Lots to learn and if one has a suitable config to share I would appreciate it !
To date I have a working Klipper on the CB1 and firmware flashed to the Manta 8P MCU. Machine wiring is almost complete [crimping tiny pins to 24AWG is a challenge]
I guess you’re looking for a pin out?
→ Click me!
A pre made (basic!!) config can be found here:
→ Click me!
For crimping, I highly recommend investing in an Engineer PA-09.
Thank you for your response ! I do have those two docs already and was going to base my config on that. As this environment is so far removed from the Arduino/MARLIN/Melzi of 10 years ago that I wanted confirmation I was at least on the right path !
I am a little confused about what I have to do with the TMC2209 drivers - just uncomment the lines for the appropriate stepper ?
#[tmc2209 stepper_x]
#uart_pin: PC10
##diag_pin: PF3
#run_current: 0.800
#stealthchop_threshold: 999999
I’m going to leave the sensorless homing for when I have it running - 1 challenge at a time.
I did get a ratcheting crimper and terminal set to aid in this but the one you suggest might be better if the die is the right width. Precise placement has the carrier strip halfway into the die otherwise it crimps the lock tang !
