Hello friends, I’m new here…I’m making a Rotary delta printer, I would like to know if there’s a way to put a bed with Cartesian Z movement? this would be a 4th axis that would go down as it was printing…like a cartesian printer
I think the benefit would be the possibility of printing taller pieces with less spaces…Example to have a taller piece, the structure of a rotary delta on both sides has to be much bigger…
Hello friends! Could someone with programming knowledge be able to change the kinematics so that the kinematic z axis does not go up as the layers are made and instead the 4th axis which would be the Cartesian Z goes down as the layers are made?
