Secondary MCU (for display) Works on Boot, Fails on FIRMWARE_RESTART
Printer Model: Voron v0.1
MCU / Printerboard:
Primary MCU: SKR E3 v2.0
Secondary MCU (display): based on STM32F042
I have a secondary MCU (you can find it described as “mcu display”
klippy 2.log.zip (1.1 MB)
). This works great on fresh powerup. however, if I issue a FIRMWARE_RESTART, I believe it is failing the “COMMAND” restart and becomes unresponsive until I pull the USB cable (power provided this way as well) for the display and plug it back in - now, a FIRMWARE_RESTART works as intended
I have the same problem. Using a restart_method of “rpi_usb” (Raspberry Pi 3B+) has the same problem as “command”. It’s also not 100% consistent for me; sometimes it resets just fine.
As a workaround, I’m going to try using uhubctl to power cycle the display external to klipper next time this happens.
I have never heard of the “uhubctl” project, but I am definitely interested. Thanks for letting me know. I wish I could submit a proper bug report on klipper github, but we can’t do that anymore…
UPDATE Unfortunately, this technique does not work for raspberry pi zero.
As a follow-up to this, uhubctl did work when I got in this situation again. I does let you power-cycle a USB port, which is basically a nicer version of the same workaround. The tool only works with some models of Raspberry Pi, and some “smart” USB hubs.
I’ve also now had this happen to a Klipper Expander secondary MCU as well, so I don’t think it’s just a thing with that particular display. Next time it happens, if I have time, I will try to get more diagnostic info because the device does seem to be in some sort of wedged state. It only seems to happen when I don’t want it to.
I’m glad that it worked for you! Unfortunately, this doesn’t work on the pi zero (no actually hub on this device). I might have to buy one of the hubs from that project, but also wish we could hear from klipper on why the restart_method: command doesn’t work
HI, same situation.
It happens almost every time. In this situation only helps reboot.
It can be reproduced when i edit config and then save and restart.
This voron displays are crap. have two of them and same bahavior.
Same problem here, dealing with a klipper-expander secondary mcu. @fwiffo have you ever been able to solve this?
looks like serious problem, but none has idea how to solve this. Still facing problems with voron 0 display.
worst thing that designed for it case. But plan throw to trash this trash.
Just wasted all day trying to get my head round this as well. What I have discovered is that when you need to reboot the RasPi, it loses comms with all the rest of the printer hardware. No amount of [Restart Firmware] will get it working again because the device tree entries for the hardware is lost during the reboot. You can prove this by re-running ls /dev/serial/by-id
Without the hardware identifying itself with its serial number, klipper cannot find your mcus.
Running uhubctl twice (with -a 0 to switch the USB ports off and again several seconds later with -a 1 to switch back on) works for some hardware but not all. eg the v0display and BTT SKR-pico both restart on a power cycle and reappear in the device tree, However if you have an LDO Picobilical this doesn’t, simply because the mcu is permanently powered by a 24V to 3.3V convertor while the previous 2 are powered from the USB.
There is a further problem in klipper in that unless ALL mcus listed in your cfg files have been found it won’t talk to any.
I found that if you use uhubctl to restart USB powered mcus, then press the restart button on the picobilical, this makes all boards re-register their serial number and then you can do a [Restart Firmware] satisfactorily.
Being a total noob, I don’t know how any of the comms work but I believe it to be some sort of token passing. I wouldn’t dare to suggest that the most logical solution would be for the authors of klipper to run a watchdog on each board so that if they have had no comms for say 5 secs, they restart and offer their ID to the host again. If the host has no commands to send, it should send a dummy keep-alive to prevent the watchdog from triggering.
FWIW, I think uhubctl -l 1-1 -p 2 -a 2 would probably work to restart USB powered mcus if I knew how the -d option worked but the default cycle delay is too short to reliably force a restart on v0display and BTT SKR.
