Having a really weird issue on my printer. I get very small layer shifts, and only at cross-sectional changes in the model. I asked for help on the Discord and managed to stump the people trying to help me so maybe I can get some help here.
In this picture, you can see two layer shifts, roughly corresponding to the beginning and ending of a chamfer on a vertical hole in the model around the midsection of the model, and some issues where the solid skin on the bottoms of the internal holes start.
And here you can see a simple extrusion calibration square, 3 solid layers on the bottom. As soon as it gets to the end of the last solid layer, bam - shifts a fraction of a millimeter and prints perfectly from there on. I have observed it 3 or 4 times on this model alone. there are no noises indicating missed steps, I watched the first 8 layers on the last one.
I’ve looked into all the usual suspects for layer shifting - belts are tight, enough (but not too much) motor current, Z-axis moves smoothly (shouldn’t have mattered for the x-axis anyway but whatever), replaced X-axis stepper driver, tried disabling stealthchop, even swapped from USB to serial communication. Hotend and bed temps are stable while printing. All software/firmware up to date. Does it with every slicer I’ve used. Never had issues running Marlin with the same setup. I can send STL and gcode files if it would help - this is driving me almost literally insane. I have seen this reported numerous times and every time the issues get closed without a resolution for various reasons.
Printer is a modified Ender 3 Pro. Hardware:
- Original heated plate with glass on top
- SKR 1.3
- Raspberry Pi 3B+ running Fluidd
- TMC2208 in UART mode on all steppers
- BLTouch 3.1
- 2x 5015 fans on nozzle
- 1x 5015 fan on stepper drivers
- 1x 4020 fan for hotend
- Micro-Swiss all-metal hotend
- Original Creality motors on Y, Z, and E
- FSYETC motor on X
Log/config files:
Thanks in advance!
