Stepper buzz x moves both x and y
If the printer is assembled, how are you determining that both motors move?
Look for rotation? Buzzing when you touch?
As initially pointed out and reinforced by @jakep_82:
  • The CoreXY is a closed belt system that couples X and Y
  • Moving into one direction (either X or Y) will inevitably cause movement in the other direction as well
  • Pure X or Y movement can only be achieved when both A and B motors move the same distance
  • Electrically and firmware speaking the described issue cannot exist, since there is no crosstalk between independent stepper drivers
While I think this is hunting a phantom, I’m open to be surprised.
The only true proof would be:
  • Remove the belts
  • Run stepper buzz while touching the not-buzzed stepper and if it now moves/vibrates as well, I’d be inclined to follow this further.
If you only buzz X (A) then the print head will move in diagonal direction but the Y (B) motor does not turn.
To get this clear I already asked for those details.
However I can’t explain it…
Solved!
@Sineos had the test that proved it.
Instead of removing the belts I slaked way off on the tension and stepper buzz worked on x and y.
It turned out to be the x carriage was too tight due to me putting in a too long screw that jammed the linear rail carriage.
Thanks to @Sineos for suggesting removing the belts!
