I wondering is there way to increase the the probe raise distannt (hop) when stow_on_each_sample is set to false? of course I can always adjust the bltouch mount to be higher just that I’m asking if it posible with-in the config itself just to avoid the bltouch scraping the bed
The Z position is set by the sample_retract_dist in the bltouch config section along with the horizontal_move_z setting of the probing tool you happen to be using (eg, bed_mesh). See Configuration reference - Klipper documentation
