I am trying out the WobbleX system on the lead screws on my dual Z printer.
After installing it, I can no longer sucessfully use z_tilt_adjust.
The way the sytem works is the lead screw nut is decoupled from the bed frame and it rides on bearings and rods to push the bed up and down (I have an ender 5.)
What happens with z_tilt_adjust now is that one side ends up going down too much too rapidly causing the WobbleX to disconnect from the bed and the lead nut spins in the air. Making it not work at all.
I think as a safety feature and to fix my issue, z_tilt_adjust could be configured to only move a single lead screw by a maxium amount per try, sure it would take longer but it would also lower the chances of anything wrong.
If it already does work like this, then sorry for wasting time and could someone lead me to the correct configuration.
