I’m not sure, but it heats the table, but the klipper does not show that it is heated
I want the temperature to equalize.
but as soon as I start warming it up, it goes into error. I can’t warm it up.
Heating and reading the temperature are two different things.
It doesn’t read my temperature.
Yeah as you either use the wrong pin for the thermistor or something is broken.
Heater heater_bed not heating at expected rate
See the ‘verify_heater’ section in docs/Config_Reference.md
Printer is shutdown
this error
Ok, let’s try this:
Keep the printer in idle.
Take a hair dryer or another mobile heat source.
Heat up the extruder. What temperature rises on the Mainsail screen?
Do it the same with the bed.
I heat up the extruder with a hair dryer, the temperature of the extruder rises, the table does not care about the hair dryer, neither the extruder nor the table rises when I warm up the table
I assume, you heated up the bed for some time.
- Either the the thermistor cable of the bed is not properly plugged in to the printer board
- the cable is broke
- the thermistor is broken
- or the thermistor detached from the bed. You can check by putting heat to the bed from below.
It didn’t help either, minus 100
Extreme temperatures can also be a result of a short circuit.
Are you sure about the the thermistor type you entered in the config?
Your bed thermistor doesn’t work. Nothing more can be done to help you. You need to fix that.
my bed thermistor doesn’t work. You need to fix that. I’ll try to fix it, thanks!
I fixed everything, now the temperature is normal, the wire has been soldered off, but now when I drive home on z, he swears BLTouch failed to raise probe
klippy (12).log (1.7 MB)
