Yesterday I installed klipper on my Anycubic i3 Mega S. But I can not to do config file for it
Printer Model: Anycubic i3 Mega S
MCU / Printerboard: Trigorilla+A4988
klippy.log (54.2 KB)
Hello, everybody!
Yesterday I installed klipper on my Anycubic i3 Mega S. But I can not to do config file for it.
A bit more descriptive would be great.
As for the log you want to use the Raspberry Pi as mcu.
Have you done all the steps in this document?
https://www.klipper3d.org/RPi_microcontroller.html#install-the-rc-script
I’m using ubuntu and here’s a new error, and I fixed that one.
klippy (1).log (128.3 KB)
MCU ‘rpi’ error during config: Unable to open spi device
Error configuring printer
I fixed this error, but there is a new Homing failed due to printer shutdown and more
MCU ‘mcu’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
