Printer Basis: Tronxy X5SA PRO
MCU: BTT Octopus Pro v1.1 in CAN-BRIDGE Mode
Toolhead: HeroMe Gen 7 rev 4, with BMG clone extruder, direct drive setup, volcano hotend 100W, PT1000 thermistor
Extruder: based on BMG clone, but actually a remix from Printables including two Omron micro switches acting as entry sensor and toolhead sensor (for ERCF)
Toolhead board: BTT EBB 42 with EDDY DUO in CANBUS Mode for EDDY_NG
MMU: BTT MMB v1.1 for ERCF v2 with EREC cutter mod and modified Extruder (see above), the cutter servo is connected to the octopus borad, not the MMB board.
CANBUS connection using BTT CEB 1.0 distribution board
SBC/Host: HP ThinClient T630 (AMD x86_64) Debian Trixie
KAMP_Settings.cfg (3.0 KB)
homing_override.cfg (11.0 KB)
custom.cfg (16.2 KB)
crowsnest.conf (3.9 KB)
btt-lis2dw-v1.0-X.cfg (1.2 KB)
BTT_MMB_ERCF.cfg (5.9 KB)
btt_mini12864.cfg (898 Bytes)
BTT_EDDY_NG.cfg (5.5 KB)
BTT_EBB.cfg (6.0 KB)
basic_macros.cfg (9.3 KB)
This makes for a rather complex config. The Octopus board refused to work with driver position 0 through 3, so I have put the x/y/Z1/z2 stepper on the higher driver numbers.
printer.cfg (63.4 KB)
plr.cfg (2.6 KB)
mmu_klipperscreen.conf (27.4 KB)
klipper_screen_macros.cfg (988 Bytes)
klipper_ramdom_macros.cfg (3.4 KB)
shell_command.cfg (156 Bytes)
update_plr.cfg (245 Bytes)
and some of the important ERCF files:
mmu.cfg (4.1 KB)
mmu_parameters.cfg (68.5 KB)
mmu_macro_vars.cfg (33.5 KB)
mmu_hardware.cfg (34.5 KB)
mmu_erec_cutter.cfg (3.2 KB)
mmu_erec_cutter_hw.cfg (485 Bytes)
Hope this helps ![]()
