Unhandled expectation on fresh reinstall !?
Printer Model: Ender 3 max neo (moded with orbiter and extruder sensor)
MCU / Printerboard: skr e3 mini v3.0
klippy.log klippy.log - Google Drive
…Hello I want to preface this with that I am a non technologically inclined art student trying my best. So if this is a stupid problem I apologize! But, I freshly reinstalled mainsail OS and reflashed the printer firmware and started getting an unhandled expectation error anytime I ran a macro, or asked it to home. Ive never had issues before and cant find anyone having something similar. Ive gone through the files trying to sniff a problem out for the last two days, and I just feel very lost! Has anyone else had this problem? Any help to point me in the right direction would be supeer supppper appreciated!!! Thank you!!!
No such file or directory: '/dev/serial/by-id/usb-Klipper_stm32g0b1xx_1C001B0003504B5735313920-if00'
The above error message simply means that the connection “address” in your printer.cfg does not exists.
Best thing is to carefully start from here Installation - Klipper documentation and especially observing the information on top of klipper/generic-bigtreetech-skr-mini-e3-v3.0.cfg at master · Klipper3d/klipper · GitHub
Hello!! Thank you for the response. I checked this earlier and it seems to be written correctly, I’ll attach a screenshot of that.
Some maybe helpful extra info is that it will connect initially just as soon as a try to home or run a macro it disconnects. Here’s a new log from this morning, klippy (1).log - Google Drive
You have errors in your macros.
I can only give you one well-meant hint: Get your printer up and running BEFORE messing with macros that you either probably do not need or understand.
Thanks got it !!!’
