Unparsed config section [update_manager ....] detected. this may be the result of a component that failed to load. in the future this will result in a startup error
Printer Model: CR-10 smart pro w/ BTT pad 7
MCU / Printerboard: not sure
If anyone can help I’d be very appreciative. I had everything running perfectly. I ran out of filament mid print and couldn’t get it to resume the print due to the machine becoming idle and not being able to Z home because the print. I was just going to start the print over. I noticed some updates were available. There was a warning on moonraker I believe that said repo corrupt. I thought updating would fix this. I pressed the update button and now my BTT pad 7 is giving me error codes on startup. xxx is mainsail-config, mainsail, crowsnest, sonar, timelapse, KlipperScreen, and some more that I can not see.
“Unparsed config section [update_manager xxx] detected. this may be the result of a component that failed to load. in the future this will result in a startup error.”
I have no idea what to do here.
Klippy.log (3.7 MB)
I agree.
Did you look for errors in your “moonraker.log”?
Good luck, hcet14
