Printer Model: FLSUN QQ
MCU / Printerboard: MKS Robin mini V2 (they renamed it to FLSUN hispeed V1.0)
klippy(10).log (151.3 KB)
The output follows the ideal dmesg output from here How-To Trouble-Shoot, but the line
usbserial: USB Serial support registered for ch341-uart
is missing and i suspect that is why /dev/ttyCH341USB0 (which shows up right now) is not mapped to /dev/ttyUSB0.
few questions:
- is this leading to klipper not able to connect (see klipper.log, connection timeout)?
- how to fix this?
usbserialdoes show up inlsmod, just that its not doing what it is supposed to
additional infos:
lsusb has the line
Bus 003 Device 009: ID 1a86:7523 QinHeng Electronics CH340 serial converter
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
uname -r
6.5.0-18-generic
LattePanda Sigma
nothing relevant in /dev/serial/by-id or /dev/serial/by-path
printer.cfg:
serial: /dev/ttyCH341USB0
[virtual_sdcard]
path: /home/nestspace/printer_2_data/gcodes
on_error_gcode: CANCEL_PRINT
[printer]
kinematics: none
max_velocity: 1000
max_accel: 1000
dmesg
[ 3.680890] usbcore: registered new interface driver usbserial_generic
[ 3.680907] usbserial: USB Serial support registered for generic
[ 3.935457] usbcore: registered new interface driver cdc_acm
[ 3.976374] usbcore: registered new interface driver btusb
[ 3.987571] input: BJYP-KX Device BJYP-KX-V2.29 as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.2/3-5.2:1.0/0003:28E9:028A.0003/input/input21
[ 4.006125] hid-multitouch 0003:28E9:028A.0003: input,hiddev1,hidraw2: USB HID v1.10 Device [BJYP-KX Device BJYP-KX-V2.29] on usb-0000:00:14.0-5.2/input0
[ 57.614680] usb 3-8: new full-speed USB device number 8 using xhci_hcd
[ 57.764250] usb 3-8: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
[ 57.764256] usb 3-8: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 57.764258] usb 3-8: Product: USB2.0-Serial
[ 57.773891] usb_ch341 3-8:1.0: ttyCH341USB0: ch341 USB device
[ 57.774073] usbcore: registered new interface driver usb_ch341
[ 365.276704] usbcore: deregistering interface driver usb_ch341
[ 365.277015] usb_ch341 3-8:1.0: ch341 usb device disconnect.
[ 365.315596] usb_ch341 3-8:1.0: ttyCH341USB0: ch341 USB device
[ 365.315726] usbcore: registered new interface driver usb_ch341
[ 376.570289] usb 3-8: USB disconnect, device number 8
[ 376.570685] usb_ch341 3-8:1.0: ch341 usb device disconnect.
[ 387.534022] usb 3-8: new full-speed USB device number 9 using xhci_hcd
[ 387.683161] usb 3-8: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
[ 387.683165] usb 3-8: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 387.683166] usb 3-8: Product: USB2.0-Serial
[ 387.685251] usb_ch341 3-8:1.0: ttyCH341USB0: ch341 USB device
