Printer Model: Siboor Voron 2.4, with Cartographer Scanner
MCU / Printerboard: BTT Octopus v1.0.1
Host / SBC: BTT Pi
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
…Hi, I just finished setting up a Siboor Voron 2.4 and Orca slicer. I am trying my first print. The printer heats up, levels the bed and does a bed mesh, where it displays a message "Unknown command:“STATUS_MESHING” It completes the bed meshing and then it displays an error message saying “Must use Touch or ADXL mode. Check your config before trying again”. The printer then cancels the print. Other errors which pop up are “Unknown Command:STATUS_HEATING” and “Unknown Command:STATUS_HOMING”. These do not prevent the printer from homing or heating. Can you please assist? Thank you in advance.
BTW, I just noticed the hotend temp only gets to 150 degreesC I checked the GCODE and It shows 220 degrees C. Odd!
KlippyLog.zip (118.6 KB)
