Wled control over Klippy
Silly Question,
i have seen in Moonraker that it supports WLED, is it possible to set a WLED controler as a neopixel strip ?
so you can show your print status via wled on another room, or use your leds on the Printer for other things
The moonraker example for WLED includes some gcode macros you can use to control the LEDs through your gcode. You can use SET_WLED pretty much the same way SET_LED to control neopixels hooked up directly to klipper.
Since WLED is wireless, it can be mounted wherever you feel like it, including in other rooms.
Yes that is clear,
i have installed Klipper-led-effect, but with this i cant control wled
