Printer Model: Ender 3 V2
MCU / Printerboard: SKR Mini E3 V2 (main), Creality 4.2.2 (secondary)
Host / SBC: Raspberry Pi 4
klippy.log (299.9 KB)
I have a Ender 3 V2 that I’ve done a bunch of things to; one of them being replacing the stock Creality 4.2.2 board with a SKR Mini E3 V2. I did this because I added the 2nd Z screw and stepper motor and wanted to have separate Z outputs. Failing to read that the Mini E3 has a parallel dual Z output, I decided to use my original 4.2.2 board as an external 2nd MCU. I’m running only the extruder and my CR Touch from that while everything else is on the Mini E3.
It all seemed to be working fine, and then I started to have issues where I would get a time out while it was probing the bed for a bed mesh, or the extruder would not be extruding. This would be after a single successful print. Restarting Klipper and the firmware would then end up giving me a MCU failure and it couldn’t talk to the external 4.2.2 board.
Played with USB cables, used different ports on the Pi 4 running everything, making sure it was still seen if I did a “ls /dev/serial/by-id/*” (which it was) with no success. Ended up remaking the Klipper.bin file and reflashing the board. Once I did that, everything started to work again.. until after a print or 2 and it would all happen again.
Anyone have any thoughts of WTF could be going on? Is the board suddenly failing? It was working fine prior to it being removed but I also know that means nothing.
Of course after I did some (failed) printing last night, when I turned it back on this morning to get a Klipper.log file it came right up. But this has happened twice so far.
