Connection to MCU Issue
Printer Model: Vovelab Aquila x2 w/Sprite & BLT
MCU / Printerboard: N32g455 v1.0.1
klippy.log (5.4 KB)
printer.cfg (3.9 KB)
I can see in the Klippy.log that the connection to the MCU is failing and it seems to say the proper address/ID is incorrect but as per the printer.cfg file which I’ve changed it to the appropriate address/ID it still Isn’t connecting. I’ve looked and read through everything twice but I’ve either missed something or I’m going nuts !!! Probably both… Any Help/Advice would be greatly appreciated. Thanks
The config file Klipper is expecting is /home/pi/printer_data/config/printer.cfg
Make sure to edit the correct one.
Hey m8, cheers for the fast response……lets pretend for a minute that I’m just a dumb old diesel mechanic whose been laid up at home after a hip replacement and spinal surgery 8 weeks apart !! I’m good with my hands so I decided to play around with my old printer and upgrade it while I was rehabbing…let’s pretend that !! lol. I’m a little bit out of my comfort zone with the programming talk, don’t get me wrong I’ll have a go at fixing anything, it’s in my dna !! I was directed to a video… “Join Klipper it’s soo easy” they said…Did that, I followed it exactly and here’s where I am. I’ve changed mainboards in the printer (H32 chipped to N32) gone through everything on my Macbook several times and finally borrowed a Windows laptop to try it all over again. So I’ve had a good crack, within my skill set and knowledge base but I’m just coming up short. I’ve had some kid on discord get smart with me because I couldn’t keep up with him on the keyboard…. I’m 59 with 2 fingers missing off my right hand so yeh I’m a bit slow. I just need someone to explain it slowly and concisely and I can follow directions very well. Any and all help would be greatly appreciated. I’m about start from scratch again and this time run mainsail instead. But to be honest I understand what you mean but I have no idea how to fix/change it !! Cheers for the response.
Get well soon!
Well, there is a certain learning curve, but I promise the result is worth the “hassle”
Mainsail or fluidd does not make any difference in the end.
Option 1
The “Configuration” tab in the webinterface should take you to the correct printer.cfg to edit.
Option 2
To have a clean start, you may carefully and methodically work through Installing Klipper with KIAUH
