Hi Everyone,
I built a Rotating delta printer and for the most part it is behaving as expected. I fully understand there is not a lot of rotating deltas out there… so i am a bit off the reservation…
I ran Delta Configuration, Enhanced delta and bed mesh to get good first layer.
Once my prints finish, especially a very short print, my printer homes itself as part of the end G-code. I then get the “No trigger on c after full movement”. Kevin did state that the rotary delta kinematics does not do error or boundary checking. How/where can I increase the “allowed” travel distance before it should raise an error?
I tried editing config file minimum_z_distance to -30, no effect (to try allow furher retraction before error)
I tried adding homing_retract_dist: 255 to the config file - klipper says this is not expected.
The printer works fine otherwise, I just need to restart the firmware after every print…
klippy.log (1.9 MB)
