"Extruder" not hot enough
Printer Model: ender 5 Pro
MCU / Printerboard: SKR mini E3 V3
Host / SBC: Rasberry Pi zero 2 / mainsail via kiauh
so been struggling to install and set up Klipper, I finally got everything working and calibrated. went to do my first print (flow cube) and i get through the bed mesh calibration and then i get "Move out of range: 360.000 360.000 10.000 [0.000] followed by “extruder” not hot enough.
Please help!!!
klippy.log (230.1 KB)
The G29 macro is the culprint:
[gcode_macro G29]
gcode =
	G28
	BED_MESH_CALIBRATE
	G0 X360 Y360 Z10 F6000
	BED_MESH_PROFILE save=default
It’s called in the macro [gcode_macro PRIME_LINE]
It appears to be a gcode command PURGE a bit later. There is no macro for it. That will be your next issue.
is issued by the macro [gcode_macro _CLIENT_EXTRUDE]
description = Extrudes, if the extruder is hot enough
gcode =
	{% set client = printer['gcode_macro _CLIENT_VARIABLE']|default({}) %}
	{% set use_fw_retract = (client.use_fw_retract|default(false)|lower == 'true') and (printer.firmware_retraction is defined) %}
	{% set length = params.LENGTH|default(client.unretract)|default(1.0)|float %}
	{% set speed = params.SPEED|default(client.speed_unretract)|default(35) %}
	{% set absolute_extrude = printer.gcode_move.absolute_extrude %}
	{% if printer.toolhead.extruder != '' %}
	{% if printer[printer.toolhead.extruder].can_extrude %}
	{% if use_fw_retract %}
	{% if length < 0 %}
	G10
	{% else %}
	G11
	{% else %}
	M83
	G1 E{length} F{(speed|float|abs) * 60}
	{% if absolute_extrude %}
	M82
	{% else %}
	RESPOND TYPE=echo MSG='{"\"%s\" not hot enough" % printer.toolhead.extruder}'
Based on this:
https://www.klipper3d.org/Config_Reference.html#extruder
and this:
https://www.klipper3d.org/Status_Reference.html#heater
You try to extrude at 150°C
Stats 36600.8: gcodein=0  mcu: mcu_awake=0.011 mcu_task_avg=0.000014 mcu_task_stddev=0.000019 bytes_write=106300 bytes_read=120576 bytes_retransmit=9 bytes_invalid=0 send_seq=6671 receive_seq=6671 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=8 freq=63997701 sd_pos=5614 heater_bed: target=60 temp=60.5 pwm=0.163 sysload=0.82 cputime=11.191 memavail=3618600 print_time=1278.530 buffer_time=0.551 print_stall=0 extruder: target=150 temp=150.5 pwm=0.113
Stats 36601.8: gcodein=0  mcu: mcu_awake=0.011 mcu_task_avg=0.000014 mcu_task_stddev=0.000019 bytes_write=106458 bytes_read=120826 bytes_retransmit=9 bytes_invalid=0 send_seq=6680 receive_seq=6680 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=63997700 sd_pos=5614 heater_bed: target=60 temp=60.6 pwm=0.040 sysload=0.82 cputime=11.221 memavail=3617032 print_time=1278.530 buffer_time=0.000 print_stall=0 extruder: target=150 temp=150.5 pwm=0.113
bed_mesh fade complete: Current Z: 10.0000 fade_target: 0.0000
Exiting SD card print (position 0)
Stats 36602.8: gcodein=0  mcu: mcu_awake=0.009 mcu_task_avg=0.000015 mcu_task_stddev=0.000021 bytes_write=106750 bytes_read=121235 bytes_retransmit=9 bytes_invalid=0 send_seq=6697 receive_seq=6697 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=63997699  heater_bed: target=0 temp=60.5 pwm=0.000 sysload=0.82 cputime=11.267 memavail=3616368 print_time=1279.478 buffer_time=0.000 print_stall=0 extruder: target=0 temp=150.3 pwm=0.000
Stats 36603.8: gcodein=0  mcu: mcu_awake=0.009 mcu_task_avg=0.000015 mcu_task_stddev=0.000021 bytes_write=106878 bytes_read=121495 bytes_retransmit=9 bytes_invalid=0 send_seq=6705 receive_seq=6705 retransmit_seq=2 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=63997698  heater_bed: target=0 temp=60.4 pwm=0.000 sysload=0.82 cputime=11.294 memavail=3623504 print_time=1279.478 buffer_time=0.000 print_stall=0 extruder: target=0 temp=150.2 pwm=0.000
min_extrude_temp default is set to 170°C
What filament floats at 150°C?
@EddyMI3D thank you for that, I corrected and removed the things causing the issues but still running into issues. its like klipper is trying to run every macro for no reason lol.
klippy.log (429.5 KB)
7:41 AM
Unknown command:“M300”
7:41 AM
Unknown command:“LOW_TEMP_CHECK”
7:41 AM
Print already paused
7:41 AM
idle_timeout: Timeout set to 86400.00 s
7:41 AM
Filament Change
7:41 AM
7:39 AM
Profile ‘default’ is reserved, please choose another profile name.
7:39 AM
Bed Mesh state has been saved to profile [default]
for the current session. The SAVE_CONFIG command will
update the printer config file and restart the printer.
7:39 AM
Mesh Bed Leveling Complete
It looks like your filament runout sensor is triggering. Did you just copy-paste some macros from somewhere? You have macros calling other macros that don’t exist.
yes lol. Never set up klipper before, I have always used marlin.
In that case just get a basic config working without macros, then consider adding macros once you understand how they work and what they do.
