I was trying to get KAPM to work and I deleted the # in front of the text that says Set to ‘True’ if you use KAMP. I had previously changed the command to ‘True’ below that line, but the config files weren’t showing up (I did install them though the root SSH). I clicked save and restart and now Mainsail is saying ‘Cannot connect to Moonraker’ and Fluidd is saying ‘502 Bad Gateway’. It advised to check the logs, but I can’t even access the page to do this. I’ve read other topics similar(ish) to this issue and everyone asks for the logs… but I have no idea where to type ~/printer_data/logs/moonraker.log to get them. I’ve tried in the SSH, web browser and file browser on my PC. I’m running a nebula pad and it was all working before I did this
I should also mention that i’m a complete novice and did all this by closely following guidance videos and articles… so speak to be like a noob ![]()
ok I found the log any help would be appreciated. :
platform: Linux-4.4.94-mips-with-glibc2.0
data_path: /usr/data/printer_data
is_default_data_path: False
config_file: /usr/data/printer_data/config/moonraker.conf
backup_config: /usr/data/printer_data/config/.moonraker.conf.bkp
startup_warnings:
verbose: False
debug: False
asyncio_debug: False
is_backup_config: False
is_python_package: False
instance_uuid: 314b5ad8857b48c8991553bf36c09ee6
unix_socket_path: /usr/data/printer_data/comms/moonraker.sock
software_version: v0.9.3-4-ga4604e3
git_branch: master
git_remote: origin
git_repo_url: GitHub - Arksine/moonraker: Web API Server for Klipper
modified_files:
unofficial_components:
log_file: /usr/data/printer_data/logs/moonraker.log
python_version: 3.8.2 (default, Jul 4 2023, 21:21:56) [GCC 7.2.0]
launch_args: /usr/data/moonraker/moonraker-env/bin/python /usr/data/moonraker/moonraker/moonraker/moonraker.py -d /usr/data/printer_data
msgspec_enabled: False
uvloop_enabled: False
2020-03-01 20:00:17,632 [server.py:launch_server()] - Server Config Error
File “/usr/data/moonraker/moonraker/moonraker/confighelper.py”, line 1081, in _parse_file
self._write_buffer(buffer, file_path)
File “/usr/data/moonraker/moonraker/moonraker/confighelper.py”, line 991, in _write_buffer
self.config.read_string(“\n”.join(buffer), fpath.name)
File “/usr/lib/python3.8/configparser.py”, line 723, in read_string
self.read_file(sfile, source)
File “/usr/lib/python3.8/configparser.py”, line 718, in read_file
self._read(f, source)
File “/usr/lib/python3.8/configparser.py”, line 1113, in _read
raise e
configparser.ParsingError: Source contains parsing errors: ‘moonraker.conf’
[line 8]: “Set to ‘True’ if you use KAMP\n”
The above exception was the direct cause of the following exception:
File “/usr/data/moonraker/moonraker/moonraker/server.py”, line 551, in launch_server
server = Server(app_args, log_manager, eventloop)
File “/usr/data/moonraker/moonraker/moonraker/server.py”, line 86, in init
self.config = config = self._parse_config()
File “/usr/data/moonraker/moonraker/moonraker/server.py”, line 164, in _parse_config
config = confighelper.get_configuration(self, self.app_args)
File “/usr/data/moonraker/moonraker/moonraker/confighelper.py”, line 1116, in get_configuration
source.read_file(start_path)
File “/usr/data/moonraker/moonraker/moonraker/confighelper.py”, line 1101, in read_file
self._parse_file(main_conf, )
File “/usr/data/moonraker/moonraker/moonraker/confighelper.py”, line 1092, in _parse_file
raise ConfigError(f"Error Reading Config: ‘{file_path}’") from e
moonraker.confighelper.ConfigError: Error Reading Config: ‘/usr/data/printer_data/config/moonraker.conf’
- Please attach the full and unmodified log
- KAMP is no longer needed as adaptive meshing is supported in Klipper directly
- It seems you added KAMP code to
moonraker.confinstead ofprinter.cfg
I’ve fixed it now, It seems like I had also enabled the time-lapse function which seemed to be creating an error as well, although it wasn’t reporting it #'ed this and it’s now up and running again. thanks for your help
