tronxy veho 600
standard control board
osoyoo 5inch touchscreen to use for klipperscreen.
i have connected the screen to the rpi and the screen works, just not the touch part of it. so i swapped out sd cards and put a non klipper pi os in and the touch part works fine.
so i then got in contact with the manufacturer of the screen, he thinks there is a conflict with the i2c address as the touch part of the screen uses the i2c “channel”.
unfortunately i cant change it for the screen so i must somehow change it for the printer. does anyone know how to do this?
thanks in advance
