Klipper on a Wanhao D12
Printer Model: Wanhao D12
MCU / Printerboard: MKS robin nano V1.2
Host / SBC raspberry pi4
klippy.log mainsail
Good day
I’m stuck on the printer not picking up the MCU , I’ve flashed the MCU with the robin.bin file for the MKS v1.2 board found in the directory dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 that is the MCU serial number that I’ve pasted into the MCU serial section in printer config.cfg, I’ve copied the printerconfig.cfg as per the Klipper config directory, in the make menuconfig ive followed all the correct adjustments, but the Pi is not able to read the MCU please assist
Hello @moewzy !
That means what?
On Mainsail you find the klippy.log here:
Please attach it to your next post as a file.
Upload
printer.cfg (1.9 KB)
See the difference?
grafik
grafik
